I bought a NOS B&M Pro Stick, and finally ordered the reverse pattern plate. But you have to fiddle with the trigger to get from ?? forward gears or low to neutral.
I'd like to just be able to slam it forward from any gear to neutral, and the only thing in the way is the top little dingle in the drawing, just to the left of the first gear line. That is the little sort of triangle shaped piece. Seems to me I can grind that out and not affect things adversely. Anyone similar?
Bear in mind it has a separate reverse lockout, so no danger of going past neutral
