Okay. A little education may be in order here. 273/318/340 cranks all share the same stroke of 3.31 inches and 2.5 main journals and 2.125 rod journals. The only differences are cast or forged construction and balance factor. 273 and early (pre 1973) 318 cranks are going to be balanced for the smaller and lighter bushed rods that came in those engines. 340s are going to be balanced for larger rods and heavier pistons. Your early (pre 1970) 318 will have the most likelihood of having a forged crank. Being you don’t have a crank that was originally outfitted to your application, i myself would look at getting a mopar specific pre balanced rotating assembly and pistons.
@PROSTOCKTOM here is a licensed Molnar and JE/Diamond/Icon dealer. First and foremost, though, I would be getting the cylinder bores professionally measured for concentricity and taper to see if what you have is usable before investing too much into it.
