Lemeee tell you about the axles I paid $555.00 for from Moser.
In a phone conversation, the guy at Moser told me if I wanted to buy axles from them, I HAD to take Green bearings. I didn't want Green bearings, because I have always heard that the OEM "tapered roller bearings" were superior, because of their ability to absorb lateral forces (road racing?), something that the Green ball bearings are not very good at, apparently.
Moser doesn't want to mess with OEM-type bearings... and, that's a shame.
But, I am not going to be road racing this old car, so I went ahead and ordered the A-Body axles (heavy duty) with 11/16", screw-in studs, and Green bearings.
They arrived with the following problems:
1. The flanges were not drilled for axle-retainer straight-on access for a socket on an extension, like stock axles are. I had to take them to a machine shop to get those access holes put in, at a cost of $42.00. (three holes per flange, as per the stock, OEM axles.) No, I didn't request the holes, but neither was I asked if I wanted them or not. I surely would have requested them, if I'd been asked. I think that's poor...
2. The holes in the flanges that were drilled and tapped to accept the threaded studs had a problem allowing the studs to "bottom-out" like they were supposed to; the studs had to be machined smaller at the interface of the threads and the non-threaded portion (about halfway up the stud) to allow for proper seating of the studs against the flange holes' outside periphery.
Luckily, my friend, who was helping me with the stud installation, had a lathe and was able to machine the studs so they'd thread into the flange holes, all the way.
3. This is a small thing, but the machine work (drilled holes, in particular) had no "finish" work done to it, leaving rough edges on all the holes, with machining "debris," still attached to the side of the hole-edge. My machinist friend thought that was really sloppy, and took a chamfer tool and smoothed all the edges before we installed the studs. For $555.00, I expected more...
Am I unreasonable?
Am I unreasonable?
