Mopar performance head gaskets
wildbill
Meridian, ID
I ordered Mopar performance head gaskets part number P4120093. Advertised as having a bore of 4.06 and compressed thickness of 0.04 - what I got are Fel pro 8553PT gaskets in a Mopar box! These have a bore closer to 4.2 and a compressed thickness of about 0.05 - no better than what came in my full gasket set. I will be sending them back. Just wanted to make sure nobody else made the same mistake.
I have just oredered a set of P4120094 gaskets which are supposed to be .024 to .028 compressed thickness and 4.06 bore. We'll see when I get them. I'll let you know.
I missed something here. wildbill, where did you order the gaskets from. I am looking to get something similar and don't want to make the same mistake. Thanks, Dennis
They were ordered from Summit. I think that Mopar performance is just relabeling the Fel pro gaskets and selling them as their own. Unless somebody returned a set of Fel pros to Summit and they accidentally resold them to me?
correct they are the same gasket....just a bad description of them
those have been like that for 20 yrs or so...used to buy them from mopar for 6 bucks a gasket....still got a few in packages from way back then
those are either 4.125 or 4.14 bore...but the thickness is correct...if i was home i could check the bore for ya...but wont be home until saturday
are those the thin ones bomber? i ordered the mopar perf thin gaskets and they were the same as the mr gasket part. whiteish blue in color
mopar p4120094 and the mr gasket 1121 are the same....now that mr gasket are 1121G...dont know if they are the same..
thats what i thought.those are good gaskets,more durable than the fel pro.at least for not popping up by the lifter valley...
