[SOLD] Mopar w2 heads
The ones above are the latest design with dual header pattern and strengthening ribs unlike these Econo heads.
The heads up top can use Harland Sharp or the or Crane/MP rockers that have bolt down stands.
It’s the same deal with W5 heads pictured below with Crane Gold rockers.
This (set of) W2 heads I have were nearly the last set sold out of Summit. Notice the wide exhaust bolt only spacing. This W2 head style is the last type cast. Super minor differences are what only can be really seen. The differences besides 48*/59*, chamber cc’s and exhaust bolt spacing, would be in the ports, if you know what your looking for, I do not.
I hope this helps. The W2 cylinder head is an excellent cylinder head with only one major draw back of being iron.
Otherwise, a talented porter can have the head scream last 300 cfm.
those are closed chamber 48 degree heads
P5249769, cast into the cylinder head as pictured above crossed reference into the last MP Catalog where you can read for yourself, 3rd line up from the bottom on the left you can see the numbers.
Thank you very much ladies and gentlemen, to the seller;
GLWS!!
To any potential buyer, this an excellent iron head.
