I have an original 1971 motor home 440 and 727 transmission with 36,000 miles on it. I'm giving some thought to installing it in a Barracuda. However, I,m wondering if the cam should be changed due to the difference in application (from a 24 foot motor home to a Barracuda) I realize there may be a difference in the front sump or rear sump oil pan (I don't recall which but, think I have both to work with). The exhaust manifold and motor/mounts will be another issue. The area I need the most help in... is setting the motor up for a pump gas muscle car (nothing radical, mild performance & street driven). Another concern is MPG. The thermoquad was working fine when I parked the motor home. Will MPG improve with an aluminum intake and different carburetor? What MPG can be expected from a 440 Barracuda under normal driving conditions with 8 3/4 & 2.76 gears? (If I can't afford to drive the car 70 miles to a car show I'll stay with the 318) I assume the same transmission and torque converter will work. (provided the drive shaft is altered)
Thanks,
:read2: Jim Wyatt
Thanks,
:read2: Jim Wyatt
