jonn6464
1970 Duster
Hey FABO,
Does anyone know if there is a 1.5" version of the biscuit style motor mount available?
Thanks for any replies.
I finally learned that I needed to leave one rubber biscuit loose on the motor mount bracket to get both sides to drop into the holes in the frame, then line the loose one up and drop it down and then tighten the biscuit. That probably applies to any thickness of rubber mounts you use, so hope that helped.
