1stBxMopar
Show your motor and plate installation..........
You sure showed yours. Looks good.![]()
Not sure if you meant a street car or racecar...
To eliminate motor mounts(breakage from torque,high HP engines)also to raise/lower, forward/back placement of engine.stupid question but whats the plate for??...gathering knowledge!!
BUMP lol. It looks like everyone is using aluminum? Anyone ever successfully used 1/4" mild steel for the front? I found that someone sells mild steel mid plates also. Any good?
Bill I have seen them in person. Use the motor plate as the swivel point for the alternator. Then use a turnbuckle with two eye hooks as the adjustment. Then you have to make some homemade spacers to align it to the water pump pulley.Yea, I'd like to see some small blocks with alternator mountings. I'm having a real tough time trying to fit an alternator on my motor plated small block in a 71 Demon.
