Will_H#24
I was under my dash on my 69 Dodge Dart Swinger and my radio has a white 3.5 mm audio adapter going inside the case I don't know if this is what it is or not. Does anyone recognize this setup?
There's also a noticable click, like a on and off with the channel wheel.That's an aux jack. Looks like someone did a nice job wiring it. If your radio works and its wired correctly you should be able to plug an MP3 player, CD player etc., into it.
I don't think it is, it doesn't seem to do anything.AM/FM?
I was thinking the same but I need to check it out. The AM part of the radio doesn't seem to be working.Maybe the click is the input select.
