skep419
5.9 Magnum 4 speed afficionado
Car-1969 DART GT
Weight-3300
Gear ratio-3.91
Tire diameter-245/60/15
Engine CID-365
Head Type-EDELBROCK
Valve size-2.02 1.60
Head Work- MILD PORT
Cam- Comp Cams 20-225-4
284 int./296 exh.Carb type and size-HOLLEY 4150HP DP
Jet sizes-74-78
Plug number and brand
Intake Manifold Type-RPM AIR GAP
Piston Make-SPEED PRO 4 VALVE RELIEF
Compression Ratio-9-1
Trans type-727
Trans Mods-MANUAL VALVE BODY
Convertor type-MIDWEST CONVERTER
Convertor stall-2800
Trans Brake-no
Drive shaft stock or aftermarket-STOCK
Initial timing-17
Total timing-35
Total advance at what RPM-2000
Rear end type-8 3/4 3.91 suregrip, single spline side gears, yukon axles,green bearings.
What would be the best mods to up the MPG?
Weight-3300
Gear ratio-3.91
Engine CID-365
Head Type-EDELBROCK
Jet sizes-74-78
Trans type-727
Trans Brake-no
Initial timing-17
Total timing-35
