MRL Performance
Here is NEW and IMPROVED Small Block Solid Roller Lifters With Offset Intake Pushrod Seats!
These are designed to work very well on SBM heads that have offset intake rockers. The offset is .180" and we shortened the body to help accommodate a 3/8" pushrod.
The are packed with High End features,
Super thick, fully hardened link bar that is attached on the inboard side of the lifter with Huge 3/8 fully hardened Rivets. The link bar is mounted on the inboard side to help in the easy of installation, no grinding required! They fit older LA style blocks as well as Magnum/Roller tall lifter bore blocks.
Some NEW features include:
Extra oiling to the roller bearing area via oil feed hole on the sides of the lifters. The oil feed holes go directly into the roller bearing on Both sides of the lifter. This ensure 100% constant oil flow to the roller at any RPM, keeping it lubed and most importantly, keeping it cool under all load and RPM conditions.
Shorter body at help accommodate the pushrod angle of the offset intake rocker arm and the use of a 3/8 pushrod if desired.
Huge .815" high alloy roller with Micro sorted bearing to ensure super smooth operation no matter what the use. These lifters will survive on the Street or Track and are made to be pushed hard and they just keep asking for more!
As always, Superior fit and finish, No Sharp Edges Anywhere as every part of the body is rounded on the corners.
You simply can not get a better lifter for the money, PERIOD!
Suggested List Price $749.99
Our Price $650 In Stock And Ready To Ship!
