famous bob
mopar misfit
will a msd 6 work at all if its bad, after up to operating temps , car is very undependable , cutting out, dieing ,but will restart -------------???
I agree that the coil would be the first suspect. When an msd goes its usually sudden and doesnt work again. A coil typically fails slowly and symptoms start when it gets hot. Its not uncommon for a coil to fail but then work fine again once it cools off.
Like I have seen, every racer has a extra box in their trailer. There's a reason for that yet many here have used MSD systems on their street cars for years with no issues. It's probably a box.have changed coils , first thing I thot about , also many other changes , runs like a 505 should till I hit a bump , then dies ...but will restart , suspect a wire grounding some where when I hit that bump...
