russhal
Has anyone else had problems with an MSD dizzy? I've used MSD products for years but can't figure out why this dizzy won't work. I have an FiTech fuel injection set up on the car. Shortly before swapping from carb to efi, my car developed a miss mid range to upper rpm. Just like with a bad plug wire. Changed wires, thought I had it fixed. One week after efi swap, starts up again. Gets so bad, the efi would lose tach signal and shut off. I Chase it down to the dizzy. Put a mopar dizzy in, problem solved. I replaced the cap, rotor, and pickup on the MSD. Put it back in, problems back. Put the mopar dizzy in, problem solved. I have a $250 paper weight. Any thoughts? MSD was no help at all.
