JoeDust451
- Joined
- Jul 1, 2005
- Messages
- 1,348
- Reaction score
- 29
Well i hooked up the streetfire & followed the instructions, checked over things twice, double checked my grounds, made sure the box was grounded, last wire i hooked up was the large red Batt wire, when i touched it too the + terminal it gave off a small spark, i though, this isn't right, so i hook it up & sure enough i get nothing (no fire), so i turned the key too "on" & check for power at the box at the small red wire, its hot, now all this time the little red "light" on the box never comes on, i disconnect the + & - leads & try it again, this time it doesn't throw a spark as i hook it up, but still nothing, there is NO WAY i hooked anything up wrong, never crossed wires accidently, so at this point i'm pist, i know MSD has been haveing quality issues, i'm done with this garbage, i've hooked up at least 4-5 MSD 6ALs over time on other cars i've done & never a problem, WTF!!
So i'm thinking its these micro-boards there useing, i did have a problem with a Procomp dist. that has those boards in it, there junk, i ended up getting one of those "ready too run" dist. that has a "module" type system & it works great.
I was going to have Jegs send me a new one, but what if this other one has problems too, or it doesn't last long, i've decided to send it back for a refund. Whats so upsetting is i was going to try the Procomp 6AL box, but was told you get what you pay for (so i past), doesn't anyone make decent boxes anymore, at this point all i want is a rev limiter, screw all this fancy digital crap.
I know some are probably thinking, why would i be complaining over "one" bad box, well its accually been 3, the other 2 i tried had issues, but they were used, plus a had that GM style (big cap) dist. from Procomp that was junk with that crappy micro-board. Just wanted to vent my frustrations lol.
