my low buck street and strip ride
I threw in that 3:55 chunk i got from that guy you knew at goodguys. Works good! My neighbors were pissed at my 2 black stripes. I just told them i have no feeling in my feet so phuck off! That seemed to work. Lol
Bitchin part,is how streetable they are,set up right.
yeah your right.got new fuel filter on the way but man i cruised it around today and it definatly makes more power with this carb on it.roasts them from a dead stop tooeasy with the street tires.456 with slicks is gonna be insane.:burnout:
nice, like jeff said this is the greatest quote of all time!had me rolling rick=D>:thumblef:[-X
got a dominator flat air cleaner base on the way,so i can still use my moroso air cleaner.now have to get four or five inch filter element, and cut ahole in the hood.drove around a little tonight, no takers. btw ufo lights out.:glasses7:
Looks good! I think I see 2 FP Regulators. You tee'd off on the fuel line and using 1 pump to feed it all. No return line? Compression? What kind of fuel? What electronics to back the timing off on the hit? How much of a hit?
Dang I got alot of questions......Lol
I started on my Fuel lines etc last night, I only made up the Dual Fuel Feed to the carb so far. The Plate I will be working on this weekend. I really like your cross through the Intake. I may look into that for mine too.
yeah for now i have 1/2 inch hard line to the -8 bulkhead a y block with -8 to the regs.-6 to the fuel bowls.-4 to fuel solinoid.have no way tobackoff timing yet.so gonna just pull it down to 30 and spray with the 100hp jetting.once i get that working good i will find somthing to retard the timing at the hit.i am at 9.9 to 1 comp.all the stuff is hooked up and functional,have a purge coming out of the cowl in front of the passenger,lol.have the purge button on the steering wheel.my bad i still need to place the full throttle switch on the carb,again.........your setup will be way more radical than mine...what i have is very entry level....start small louis.work your way up.get that stroker in there you got some 9 second slips coming your way onceyour dialed...
well i should have everything to set the gears up.gonna do that this week.talk about a big jump in leverage, this should be epic .:burnout:
"Aw man, he ruined a perfectly good hood!!!!"
I hear that all the time :finga:
Sweet, love it Mike :glasses7:
now need some fentons for the front.15 x 4 or some real cragar super trick fronts. nostalgia baby.....
