My next crazy project.
When the SHTF we all may need a different way to get around.
Friction mount main shaft to the rear tire. You will still have brakes with the pedal and chain assembly that came with the bike.
Friction Drives:
Tire to Tire Drives like they use to run the Tilt-A-Whirl ride decks at the county fairs:
Good Times, Keep Thinking . . .
That's pretty cool. I thought about doing a rear mounting engine and have the chain straight up and down. But I think it would look much cooler tucked underneath. Im gonna have to cut and fab the frame some to make it fit but I have a plan.
"A caution".........
This is my last recument trike
The engine in question is not mounted in this older photo. I had bought a small 4 stroke for it because I figured it would "pull" at lower RPM and be a bit more quiet.
Now this trike is "1 wheel drive" off the chain. The left wheel idles on a shaft. I made a new shaft and modified it so the left wheel is driven by that new shaft and connected an ELECTRIC drive to the left shaft
When I got the 4 stroke I left that all connected, and added a second sprocket to the RIGHT shaft and connected the 4 stroke to that. So now the pedals and 4 stroke drive the right side wheel
The "CAUTION?"
The 4 stroke, even though small and not very powerful, DESTROYED the right hand wheel by stretching the spokes. I am guessing the constant "pounding" by the "put put put" applied a "pulsing" energy which stretched and ruined the spokes.
This all happened in the space of one summer
My advice: Drive the wheel with friction, or find some sort of alloy wheel, etc
Also be aware that (so far as I know) all the commercial bike engines meed a maximum HP/ CC figure for unlicensed operation (at least in some states)
By using a lawn more or other large engine such as this, you might be "in danger" of law enforcement. Check what you are up against in your state.
That is really cool Del! Thanks for thr caution. I believe on a trike like that a live axle would be the way to go. They are relatively easy to do. I plan on doing a drift style trike eventually. I have alot of stuff I want to build haha
