Mystery Connection Near KickPanel
Electrical and Ignition
  1. Duster7286
    Duster7286 Well-Known Member
    225
    15
    Nov 9, 2007
    Local Time:
    10:36 PM
    Working on my 1974 Dart Swinger and was looking for a 12V Constant source for my stereo install and came across this connector driver side under dash in kickpanel area, it has blue with white tracer. I've looked at the wiring diagram but can't figure out what it's for, any one know?
    Thanks
    Also would it be ok to connect a set of temp/oil psi gauges with the 12v switch radio wire? (tie all three to the red wire at radio connector) 20200621_212305.jpg 20200621_212300.jpg
    Thanks again!
  2. MoparMike1974
    MoparMike1974 FABO Gold Member FABO Gold Member
    2,337
    1641
    Jun 16, 2017
    Maryland
    Local Time:
    11:36 PM
    Beats me, I have the same wire dangling under my 73's dash.
  3. Lord Sparky
    Lord Sparky Well-Known Member
    245
    176
    Dec 2, 2019
    Carlsbad, California
    Local Time:
    8:36 PM
    Check to see if it’s hot when headlights are on. I think mine was hooked to some gauges, but not dimmable.
  4. abdywgn
    abdywgn dismantler
    1,322
    635
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    10:36 PM
    plug for under dash lights if ordered?
  5. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    59,271
    27565
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    11:36 PM
    I think it is for the rear defogger option. Hot with the key in the run position?
  6. RedFish
    RedFish Well-Known Member
    24,192
    2808
    Sep 5, 2007
    Local Time:
    10:36 PM
    Modern head units need a switched hot and a hot at all times so thats all you really need to know about this wire. I know blue w/white was switched hot in earlier models and I know it wasn't fused. Your diagram should show its origin, if you'll need inline fuse or not.
    The factory radio supply is switched and is fused. Gauges add very little load so yes that wire can supply added gauges.
    • Like Like x 1
    • Agree Agree x 1
    • Oldmanmopar
      Oldmanmopar Going left turning right FABO Gold Member
      8,214
      4353
      Jan 8, 2009
      Danielsville Pa.
      Local Time:
      11:36 PM
      Rear window defogger
      • Like Like x 2
      • Agree Agree x 1
      • Duster7286
        225
        15
        Nov 9, 2007
        Local Time:
        10:36 PM
        Thanks for the help everyone!!
      • Duster7286
        225
        15
        Nov 9, 2007
        Local Time:
        10:36 PM
        Where is the best place to tap for hot at all times- the fuse box or is there somewhere else better?
      • RedFish
        24,192
        2808
        Sep 5, 2007
        Local Time:
        10:36 PM
        If you'll use a wire tap and break wire casing, the hot at lighter well will work. Your fuse box has unused male spades on the buss bars inside it. There is a lot more power than req'd for a stereo memory and these small wires anywhere you go. Fuse protection should be placed close to the source.
      • 67Dart273
        67Dart273 FABO Gold Member FABO Gold Member
        43,000
        10579
        Oct 14, 2010
        Idaho
        Local Time:
        8:36 PM
        Say that again!!
        • Agree Agree x 1
        • str12-340
          str12-340 FABO Gold Member FABO Gold Member
          1,039
          562
          Dec 26, 2012
          Vashon, WA
          Local Time:
          8:36 PM
          what about the switched hot feed for the original radio...???
        • Duster7286
          225
          15
          Nov 9, 2007
          Local Time:
          10:36 PM
          So hooked up stereo and underdash gauges, turn ignition to ON volt meter was reading 12v, stereo wouldnt turn on. Packed it up for night. Went back out today, checked the 1A in line fuse (looks good) checked fuse box all look good. Checked 20200629_183742.jpg grounds, tight and on clean metal.Turn key back to On... voltmeter no longer reading and still no stereo. Any thoughts? Not sure where to look...heres what I did wiring wise..what am I missing?
        • Lord Sparky
          245
          176
          Dec 2, 2019
          Local Time:
          8:36 PM
          I believe mine is set up the exact same way.
        • RedFish
          24,192
          2808
          Sep 5, 2007
          Local Time:
          10:36 PM
          Drawing doesn't look right. The constant 12 volt( tap at lighter well ) for radio memory/clock needs inline fuse. switched 12 volts at factory radio wire is already fused at the fuse box. 1 amp fuse where its shown should have blown.
        • Duster7286
          225
          15
          Nov 9, 2007
          Local Time:
          10:36 PM
          Ill add an inline fuse, its a AutoSound 230, came wired that way. Going to replace fuse in box as well. Thanks
