need 4 speed help firewall hole dash dash hole
ev2
old guy
calgary alberta canada
were did the factory drill hole through firewall? were is the dash light to be mounted ? the factory spot
the reverse light wire goes through the bulkhead connector.
the center of the light is 2" left of the ash tray wall.
nope only the back up wire to the tails goes through bulkhead there should be hole for grommet dash light wire in the firewall
There is a light for reverse on the dash?
i have a 71 duster auto org
cloning to a 4 speed car
need to know were to drill 13 /16 hole in firewall
and hole in dash
pictures i posted are from a factory 4speed 71 demon and my clone 4speed car
some wires remove at the time when i took pictures of car
you can see holes but need to know for sure were to drill
don't have the demon anymore
the hemi orange car is the clone 4speed car
i would like to drill holes
but the right measurement i don't have
don't have other factory 4speed car to check from
a tap measurement from the ash tray to the center of the hole
a measurement from the under side edge of the dash to the center of the hole
and to confirm hole location on firewall for dash rev light grommet
O I see now. All that 4 speed talk was throwing me off. LOL
Never hered or seen a revers light. My car does not have one so I cant help you out on that. But here is a bump. I am sure some one will see this that has one and help you out. Good luck.
