65LoveAffair
Whovian
I have a Snapper 28cc gas trimmer that is about 3 years old. I use it maybe 3 or 4 times a summer, at most. I went to start it up today, and at first it ran fine. I got a little trimming done, and then it started bogging down when I hit the throttle. Eventually it died. It started right back up and idled fine, but when I hit the throttle it died again. I thought maybe, even though I put Stabil in the gas, that it might be a fuel issue, so I disposed of the fuel in the tank (properly!) and put in some Trufuel 50:1 I bought at Farm & Fleet. It's 93 octane ethanol free with oil premixed into it. I changed the spark plug and I also checked the air filter. It was fine. I started the trimmer up, and it ran fine again until it warmed up. At that point it bogged down and died again. The only adjustment I can make on this trimmer is the idle speed. Everything else is set at the factory and not adjustable, supposedly. I really haven't investigated this. From what I've seen online, people with this problem have fixed it by things as easy as running Seafoam through the gas tank and as drastic as replacing the carburetor. While replacing the carburetor is cheaper than buying a new trimmer, it's a little cost prohibitive at the moment. Anybody have any suggestions? Also, if I put Seafoam in the gas tank, is that going to mess up my fuel/oil ratio? Thanks in advance.
