Need brake line installation ideas
OCswinger
McKinney, Texas
Hey guys, I recently converted my rear drum / 7 1/4 set up to a Dana 60 with disc brakes. I already had disc up front but wanted disc all round. I am looking for visual aides on how you guys out there (that are running similar set ups) are running your brake lines to the rear.
Are you running stock Prop valves? What distribution blocks are you going with?
Just trying to get some ideas here. Thanks FABO
That's exactly what I did with my car. When I get home, I'll check my records for exactly what I have. I'll go snap some pictures after work.
PM me so I remember.
I am in Sonoma county, so if you are close, you can come by and take a look.
Thanks!!! I'll remind you as soon as I'm off work
Rear disk on 8.75 rearend.
Yea. What you don't see in my pictures is a huge pile of crumpled up stainless brake line, and a whole bunch of unused stainless fittings. LOL!!!
HAHAHHAHA I know that feeling. I have so many left over AN fittings from my fuel system, I don't know where or why I bought so many of the SAME fitting.
That's why they make coat hangers. To figure out your game plan first. Cut off the fittings and reuse them.
I bought all my stuff from Cass at Dr. Diff. here's a cut/paste from my order. I forgot to get pictures and I am not up for going out and getting them now, dealing with a sick son. I'll try to snap the pics tomorrow.
Product Price Quantity Subtotal
1 Piece Distribution Block
Options:Car: All Others;
$85.00 1 $85.00
10.7" Rear Disc Brake Kit
Options:Caliper Color: Black; Add Rear Disc Brake Lug Studs: No; Upgrade to Drilled/Slotted/Plated Rotors: No; Add Custom Parking Brake Cables: Yes (+$100.00); Year and Make of Car: 68 barracuda;
$700.00 1 $700.00
Front Brake Line Selector
Options:Model Year: 1968; Platform: A-Body; Model: Barracuda/Cuda; Master Cylinder: Standard Power Booster; Front Brakes: OEM 4 Piston Calipers; Firewall Line Position: Right firewall line run under frame rail; Caliper Position: Rear; Choose Brake Lines: Complete Front Hard Line Package (+$59.00); Add Flex Hoses: Short Rubber (+$35.00);
$94.00 1 $94.00
Front to Rear Brake Line Selector
Options:Model Year: 1968; Platform: A-Body; Model: Barracuda/Cuda; Front Brakes: OEM 4 Piston Calipers; Body Style: 2 Doors; Rear Brakes: DoctorDiff 10.7" Disc; Brake Valve: Re-use Existing Dist. Block for 4 wheel drum or 4 wheel disc; Choose Brake Line Material: Original (+$50.00);
$50.00 1 $50.00
Rear Axle Brake Line Selector
Options:Model Year: 1968; Platform: A-Body; Model: Barracuda/Cuda; Rear End: Dana 60; Rear End Width: 57 1 /2"; Vent Bolt Location: 11 1/4" from Center of Housing; Rear Brakes: DoctorDiff 10.7" Disc (lines come semi-pre-bent); Choose Brake Line Material: Original Material (+$25.00); Add Rearend to Body Flex Hose: DOT Stainless (screw-in type) (+$50.00); Add Brass Tee: Yes (+$15.00); Add Vent-Bolt: Yes (+$15.00);
$85.00 1 $85.00
$700.00 1 $700.00
$94.00 1 $94.00
$50.00 1 $50.00
Thanks!!! I really appreciate it. Thanks everyone so far for input. I can always count on FABO for info and help.
Notice my calipers are in the rear of my front rotors to clear the sway bar.
