tekslk
Just installed brand new holley 770 seams to work real good, EXCEPT jump on throttle from dead stop and there is about a 1 second hesitation bog are my secondaries opening too quick or do I need more accelleration pump?
67 barracuda 2800lb 391 gears dual exshaust 360 30 over purple shaft cam vacume secondaries, great at idle, great response down the road, Just falls when you dead step it off idle.Well, gee could be a LOT of stuff. If you put that on say, a stock 318 with single exhaust, then, yeah, it'll bog.
More info--
car, weight, gears, engine specs, etc??
I have not kept up on Holley. Is this a vacuum sec, double pumper, what.
What you running for cam, exhaust, cid, compression, distributor, timing, advance curve........?
14 initial 38 total no vacume advance hooked up.Where's your timing at?
Im not ignoring car isn there right now what ever is stock is what is in it Im not sure right now.Hey tekslk, if you are ignoring what I posted....you're missing out.
All I'm going to say is for your motor you would have been way better off with the 670 Avenger. Right now your over carbed.
After your lengthy post on carb selection, and all the advice you were given, you think you would have made a better decission CFM wise.
I hope you can make it work, but it looks like you will be buying unecessary parts where a 670 would have been a bolt on. Hopefully I'm wrong.
(OUCH) nothing like getting spanked when your a grown man buy someone you dont know... youll get it worked out, i had an 850 dp on an stock 340 with a purple 509 and i work out hesitations and blubbers do your timing an listen to 1wild, youll get it. as far as im concerned you did take good advice
He needs to get other areas sorted out before worrying about the carb at this point.
It's a VACUUM secondary carb, sizing is not as important as with a DP carb. It's basically a 2bbl carb. Might the signal be stronger with a smaller carb, of course, will the guys carb work once tuned up, yes it will.
this is a very good point thanks crackedback for some good common sense very often over looked
think about it 340 6pk wow talk about over carbed oh ya its a vac secondary set up
Heck, if thats the case why stop at a 770 then ?
Why not put an 1150 Dominator on the dang thing ?
The math is good to determine a MINIMUM sized carb to perform well. If that MATH was so infallable, why does a nasty 360 with a 1050 dominator make more power and run harder than a "correctly" sized 600ish carb. Still going to follow the outdated pressure drop assumption and VE component they tell you to include?
All carbs have something redeeming about them. Everybody has an opinion and I enjoy reading the Holley bashing.
Like I say, pick you parts, pay your money.
Im a happy camper going to a cruise tomorrow.
