TomSchichtel
73 Duster
Hi there I have a 75 360 at the machine shop right now which is 20 over which the machinist is going to take to 40 over. He is going to line bore it and turn the crank and recondition the rods. He is completely redoing my j heads (I plan on using stock rocker arms) , and he will balance everything.
The build is going into a 73 duster with 3.23's and an 883 tranny. I want to use a split duration cam and am going for street/strip application. What compression ratio should be my goal? I am going to be meeting with him on friday what are some specs I should find out from him in order to start matching up my cam and pistons.
Also I will be bringing him my flywheel for balancing reasons and i need to purchace a harmonic balancer. I'm looking at either the summitracing, mopar performance or dorman brands for the balancer because of their price range. Which do you recomend? I wouldn't mind just buying the Dorman because it is so cheap but I would like to know what you think of that first.
I feel like the output of my motor will be night and day with the selection of correct pistons and cam so if there is any advice on which combo to buy I would be very grateful!
