EASY. You have points, right? You have a dwell meter? Scare up a spare condenser.......(capacitor).........the one in the distributor
Unhook the "key side" of the ballast so you can use a clip lead to jumper power to the coil through the ballast. Don't leave this connected for long, only just while you are testing.
so jumper power to the ballast
"Rig" a wire and clean spark plug or better yet a spark tester gap (parts store) to the coil tower. Crank the engine and see if you have anything.
NO? Determine if the points are closing/ drawing current or opening
to do that, simply put a light or meter on the coil NEG. With powr to the ballast, and the points closed, you should read a low voltage, say, .5--1V maybe less. Less is better, shows the points have low resistance
Bump the engine see if the voltage goes up to "same as battery." This shows the points are opening.
If the above is OK and no spark, try a different condenser. If that does not work try a different coil
OTHER caveats: Sometimes the advance plate is not grounding well, rust, corrosion, etc. the points have to ground through that. The dual points dists have a dedicated ground wire, but you can add a small gauge one. This is easily checked with your meter
With points closed, and ignition powered, measure voltage between advance plate (points ground) and the distributor case. Wiggle it around. If you get close to zero, it's fine
Points get corroded sitting. This would be a good guess
Condenser. These go bad with no explanation. In today's world, a new one does not guarantee good
Distributor wire. These DO and HAVE opened inside (from flex) or shorted to the case where they go through the hole
