LivewireBlanco
No, on the car. Timing is not set yet. I'll take that as a yes since it can be done outside of the car.You mean with the dist out of the car? Yes if you ground the housing
Big spark! Wish me luck! I'm plugging in the wires now!
No problem, just rotated distributor to gap the points got a nice spark. Going to give it a go after a quick check of everything.OH!! I was typing. What was the problem?
Sounds good!At higher RPM you need WAY more than 12. In fact you could set idle probably as much as 15-20 for break in. Keep the RPM up with cam break in.
