Need help identifying air tool quick disconnect fittings
Weak440
Thread Killer
USA
I am working on setting up my air compressor and want to use the same air chuck/quick disconnect fittings that my Dad uses. That way if I need to borrow his tools or if He wants to borrow mine... there will be no un-nessecary headaches.
Now, I have always assumed that what He used was a High Flow version of the industrial fittings that every one elses uses. But, I am having trouble finding them new.
I know that He used to do automated welder repair and worked with hydraulics on a daily bassis. Is it possible that these are actually hydraulic fittings? Has anyone seen an air fitting like this before?
I have attached a couple pics, The fitting that I am looking for is the shorter one on the right. The taller one on the left is the standard air fitting that I have always seen.
Has anyone ever used an air fitting like this?
I'm not familiar with the one you are looking for,
Found this if it helps
http://www.hfifluidpowerproducts.com/milton-quick-couplers.html
http://www.centralstateshose.com/Couplings-and-fittings-for-air-hose_c_86.html
In the days of my parts store 'career' there were several
Lincoln looked like the one you have only with a really long snout
http://www.autotoolworld.com/thumbnail.asp?file=assets/images/LN11660.jpg&maxx=420&maxy=0
What you have, I have always known as "Hanson Milton"
http://www.fixtires.com/prodimages/am_731s.png
There is "Tru flate"
http://www.plews-edelmann.com/assets/1/21/DimThumbnail/12-602.jpg
Aro Speed
http://thumbs2.ebaystatic.com/d/l225/m/mjjD1dFXl6KK-CyeQbG27fQ.jpg
And about the time I "got out" of parts, some oddball thing showed up being sold by Sears or Wards
Frankly, I would bet that your Hanson-Milton are a LOT more common, so what I would do, is just "rig" an adapter. If you can figure out what "they are" buy a matching coupler, and stick one of your nipples into it so that it fits your air hose.
