mwls73duster360
Bad as Buddy Holly
ok so i have a 360 changed my oil pump put high volume in it changed filter and put 10w 30 in it it reads correct on start at 40lb then drops down to right around 20 at idol like normal but after i drive for awhile and the oil heats up its reading like 8lb and can hear a lifter tick was told to just run like 10w 50 and it should fix it idk need suggestions of what it could be i also changed the oil pick up unit in the pan when i changed the pump :banghead:
