in the process of rewiring my sons 72 416 Duster, we used a painless universal 12 circuit fuse box, original (new) headlight switch new forward/rear lamp harness from year one, new brake/stop switch,
this is what works:
i have parking lamps working along with headlights,
all turn signals work
Hazzards all work except passenger rear
no brake lights at all !
with my test light, i have power at both sides of brake light switch
up at turn signal switch right side connections there are 6 terminals (rivets) upper bank has 3 rivets - small wht wire #1, second rivet has no wire but looks like it is bridged to #1, third rivet tan wire,
lower bank #4 has heavy white wire, next rivet #5 has pink wire, next rivet #6 has green wire.
here are my test results with test light.
1 - with everything off all rivets are dead except #5 pink wire is shows dull light
2 - with brake switch on both white rivets #1 & #4 show power (bright test light) what confuses me is that the rivet #1 has power but the wire attached to this rivet has no power - this is the wire which feeds the turn signal cam on the left
3 - hazzard switch on - no brake lights - rivet #1 is dead but wire attached to it is hot and turn signal connection on left is hot, rivet #2 which is bridged to #1 blinks bright, rivet #3 (tan) blinks bright, rivet #4 heavy white shows constant bright, rivet #5 (pink) blinks bright, rivet #6 (green) blinks bright.
what i did note: if i jumped rivet #1 to the small white wire attached to it the brake lights do go on (both sides) and the brake switch works.
here is a pic that i borrowed from this site of the switch mechanism which is exactly like the one i'm dealing with.
i am completely stumped !
this is what works:
