Need help removing front bench from 74 valiant
74val4door
california city
i ran into a problem removing the seats today and cant figure out how to remove the front bench seat:oops: so any advice would help thanks.... (im running out of time for mats 2012 ha ha)
The studs for the seats go through the floor. There should be four (4) nuts underneath the floor pan, one at each corner of the bench seat. Undo these, and the bench should lift straight up. Any wiring will be fairly obvious underneath the seat, above the carpet. (I believe in 1974, there were some wires running to seat-belt monitors, but I'm not sure). Make sure to check for wiring before yanking it out.
Good luck.
-Mike
just hope who ever had the car before didnt weld the studs to the floor I Have seen that one before cut cut cut
