Need help with 74 Valiant A/C
redneckmba
Active Member
South Louisiana
I am diagnosing :banghead: the a/c in a 1974 Valiant and I could use some information. It has factory a/c
Is the switch that is mounted on the dryer-receiver a high pressure cut-out switch or a low pressure cut-out switch?
To control evaporator temperature, does this vehicle use a low pressure switch or does it use a de-icing switch?
Does anyone know the high and low pressure factory specs for this A/C?
THANX!
Carl
