need help with brakes
kenny b
kenny b
perth ontario canada
I have installed the Wildwood setup on my demon which went great. Next was the master and booster including the metering block. It came with no instructions and I thought to myself, No problem. The metering block dosn't look the same as the old brass one from the four wheel drum setup. I have been bleeding the setup and can't get any fluid from the rear wheel cylinders. The master has been bench bled before the install. I may have the lines in the wrong places. Does anybody know which line goes where and could possibly post a pic. I am including a pic of my setup and would appreciate any feedback.
kenny b
That looks correct to me.
When I redo brakes I use a Might Vac to draw brake fluid to the wheels by attaching it to the bleeder at each. I then finish off with a traditional pump the brakes with a one way check valve on the bleeders.
