Need help with valve springs for roller cam
gtmopar
Phuckin A!
California
I'm getting a set of 360 heads done and I'm having trouble finding a set of valve springs that will work with my combo. The cam is being cut right now and max lift is .530 so its not that much. What springs do you guys recommend that aren't super expensive.
solid roller or hydraulic roller?
installed height needed?
Installed height roughly 1.750. I need 400lb pressure not sure spring diameter yet ill have to check.
What does the cam company recommend? They might have a recommendation.
400 seems high ,for a hydraulic roller. Must be spinning it up.The Hughes 1110's are good to 320 open,.550 lift.
It was just a rough baseline that the cam cutter said would be more than plenty so I'm sure mid 3's would be plenty, but thanks for that part number ill check it out.
If the Magnum,get the matching retainers. A true drop in .Best of luck.
