VIZ
The basics are 1969 block 60 over 11.8 probe pistons 4" forged crank H beam rods. Ok now the heads are the B1BA heads and the reason is I am running a vintage srt- 12 cross ram. 1st question is I want a solid roller and I am going to have T&D rockers which oil through the pushrod. I have heard that takes to much oil from the crank, low oil pressure at idle. Anyways what is the proper oil mods for this? 2nd I talked to Brian at IMM engines, the one that did the 621 hp stroker in the oct. Car craft mag. He said the way you get these heads to flow is plug pushrod hole w/aluminum port the hell out of them run the offset rocker redrill pushrod hole. Ta da, a square port w2 anyone know any thing about this? Ok 3rd the cam. I know this manifold can really make a motor a Pig if the cam is wrong. How do I go about a cam. This I feel has to be someone that knows cross rams for one. Comp cams referred me to the cam selection by rpm I wanted to shift at and the stall I had. Ok guys school me.
