Mar 11, 2011 #1 C chubsgts Well-Known Member Joined Dec 20, 2010 Messages 433 Reaction score 0 Location mi i need all the part numbers 4 piston K/H napa does not have a book for 68 need rotor numbers bearing and seal numbers rubber break line numbers and numbers you can think of for break system thanks
Mar 11, 2011 #2 3404speed Ancient Decrepit Member Joined Feb 9, 2005 Messages 2,027 Reaction score 79 Location Gillett, Pa CAL SE4958 left front caliper CAL SE4957 right front caliper I don't see rotors on the Napaonline site. or bearings specified for rotors hoses UP 36582 will work They might be available, if the catalog is used
Mar 11, 2011 #3 hemi71x hemi71x FABO Gold Member Joined Dec 22, 2009 Messages 8,252 Reaction score 4,677 Location Rancho Cordova, CA Here ya go. NAPA numbers. Hoses 36654 Seals 17110 Outer Bearing BR2 Inner Bearing BR6 Don't know if NAPA can get rotors or not for the early A body cars. I personally never have purchased rotors that i needed thru NAPA, so i don't know.
Mar 11, 2011 #4 grimreaper Cross Member Joined Jul 8, 2005 Messages 3,631 Reaction score 1,287 Location Gillette, WY Mfg Part # 68 brake hose Dorman H71319 Caliper Centric 12163005 Bearing Timken SET2 Bearing Timken SET6 Wheel seal Timken 6840S Caliper seal kit Raybestos WK518 Brake Pad Bendix D-11 Rockauto.com has the Calipers
Mar 11, 2011 #5 grimreaper Cross Member Joined Jul 8, 2005 Messages 3,631 Reaction score 1,287 Location Gillette, WY OOPS wrote caliper in place of rotor... corrected as below Mfg Part # 68 brake hose Dorman H71319 Rotor Centric 12163005 Bearing Timken SET2 Bearing Timken SET6 Wheel seal Timken 6840S Caliper seal kit Raybestos WK518 Brake Pad Bendix D-11 Rotors available from www.rockauto.com
Mar 12, 2011 #6 C chubsgts Well-Known Member Joined Dec 20, 2010 Messages 433 Reaction score 0 Location mi ok so all those break lines are female on both end does any one have photos of the KH calipers with lines hooked up or what peaces ill need
Mar 12, 2011 #7 4spdragtop FABO Gold Member FABO Gold Member Joined Aug 28, 2009 Messages 44,252 Reaction score 28,978 Location Ontario Parts Unknown Hey chubsgts, I have a factory 68-70 parts manual on cd. Enuf part #'s to make you cross-eyed. Send me a pm if you are interested. Thanks 4spdragtop
Mar 12, 2011 #8 3404speed Ancient Decrepit Member Joined Feb 9, 2005 Messages 2,027 Reaction score 79 Location Gillett, Pa
Mar 12, 2011 #9 C chubsgts Well-Known Member Joined Dec 20, 2010 Messages 433 Reaction score 0 Location mi ok so the hose is female female and hooks into the cross over lines correct
