need kelsey hayes part numbers break lines bearings
chubsgts
mi
i need all the part numbers 4 piston K/H
napa does not have a book for 68
need rotor numbers
bearing and seal numbers
rubber break line numbers
and numbers you can think of for break system
thanks
CAL SE4958 left front caliper
CAL SE4957 right front caliper
I don't see rotors on the Napaonline site.
or bearings specified for rotors
hoses UP 36582 will work
They might be available, if the catalog is used
Here ya go.
NAPA numbers.
Hoses 36654
Seals 17110
Outer Bearing BR2
Inner Bearing BR6
Don't know if NAPA can get rotors or not for the early A body cars.
I personally never have purchased rotors that i needed thru NAPA, so i don't know.
Mfg Part #
68 brake hose Dorman H71319
Caliper Centric 12163005
Bearing Timken SET2
Bearing Timken SET6
Wheel seal Timken 6840S
Caliper seal kit Raybestos WK518
Brake Pad Bendix D-11
Rockauto.com has the Calipers
OOPS wrote caliper in place of rotor... corrected as below
Mfg Part #
Rotor Centric 12163005
Bearing Timken SET2
Bearing Timken SET6
Rotors available from www.rockauto.com
ok so all those break lines are female on both end does any one have photos of the KH calipers with lines hooked up or what peaces ill need
Hey chubsgts, I have a factory 68-70 parts manual on cd. Enuf part #'s to make you cross-eyed. Send me a pm if you are interested.
Thanks 4spdragtop
ok so the hose is female female
and hooks into the cross over lines correct
