I bought Bendix part#PRT1054 from Rockauto and are tapered also. Then I ordered Centric part#12763005 and they measure the same.All the rotors I have, have a taper from disc to hub. What brand discs do you have?
Yes. It rubs the same on both rotors. This is the first set of these K-H brakes I have bought. So Im not real familiar with them. It came with new bearings, rebuilt calipers, new lower ball joints and needing only new rotors.Does the rub go around the entire rotor or just a section of it?
It rubs around the whole entire surface of both rotors, evenlyYes. It rubs the same on both rotors. This is the first set of these K-H brakes I have bought. So Im not real familiar with them. It came with new bearings, rebuilt calipers, new lower ball joints and needing only new rotors.
Thanks everyone for the help!!!
Did you let the air out of the bellows?
Wow thanks guys for the responses!!Did you let the air out of the bellows?
Waitaminit. Is there a portion of the piston, not covered by the pad? It kinof looks like it. That would not be right.
It's really hard to tell, but that geometry looks off to me.
Great pics PISHTA. Now thats what mine should look like. What brand of rotor are you running?I got some pix of mine, I got about 3mm of clearance on brand new pads. Rotor is a little rusty but that would only make it worse in my case. No signs of contact on my rotors, or on dead spider. View attachment 1714957237 View attachment 1714957238
Im no expert but by the pics pishta sent I think my problem is in the OD of the rotors. Seems like pishta's rotors are not tapered like my aftermarket rotor.Great pics PISHTA. Now thats what mine should look like. What brand of rotor are you running?
I'm thinking these newer rotors are machined differently than the originals.
Defintely Im thinking the same about the machining too. I want to try the reproduction restoration rotors from Jims Auto Parts but didnt want to pay the $130 a piece for em.I'm thinking these newer rotors are machined differently than the originals.
Ok cool, I will look into it. Thank You Cuda68Scott!One member who posted a KH conversion thread used Wagner BD60257 rotors and apparently had good results.
Cuda68Scott,I just purchased a KH setup from a member here and should be getting them in Friday. So I was looking around for rotors and saw the Bendix on Summit for $21, and thought that was a pretty decent deal. I have never had fitment issues with aftermarket rotors/drums on other vehicles so did not even think about that being a worry! Probably be several weeks before I get to installing the setup, and I plan on rebuilding my own calipers. Not sure if I will return the rotors to Summit, will be watching your thread closely!
After thinking about this problem a bit more last night and looking at the pics on this thread it seems like the issue could only be the following things:
Rotors: Manufacturing tolerances off (Chinese quality control!)
Calipers: Maybe some variances in caliper castings from KH's? Not sure if this is likely, but it seems like other mopar castings seems to have a few differences. Also did aftermarket brake manufacturers every produce copies of these KH calipers for the market? Maybe worthy discussion in a new thread.
Caliper Bolts: I suppose using non original bolts could possibly put the caliper slightly off alignment when attaching to the spindle. I know you said you have the original OEM bolts, but how did you verify that? Since you said you were unsure about whether your calipers were rebuilt or swapped for remanufactured, it made me question the certainty on the factory bolts. One caveat is that I have not heard of anybody having issues using non OEM bolts on these. But most bolts are made in China these days.....
Dust seals: Maybe just a little more meat than the originals? The ones in your pics sure look normal to me.
Cuda68Scott,
I wound up using the Centric rotors. They are still real tight but after "massaging" the dust boots to slightly flatten them with heat I got enough clearance. I was going to try The Ram Man Inc as they supposedly have the original rotors for $225. The caliper bolts are indeed the original factory special shouldered bolts. Its all in the cheap chinese rotors. Please let me know how your rebuild goes and send pics too.
Thank you!!
