Need Some Help
racefan55
Member
i have a 73 dodge dart sport and i just bought a set of 15x8 american racing outlaw rims for it.. i am trying to find the right size tires to put on the rims.. i dont want them to rub.. my main concern is the front tires rubbing.. please any help would be great.. i just dont want to buy 4 tires and they not work.. the dart is stock, never modified..
thanks!
When I bought my 73 Dart Sport it had 15x7 rallys with 245/60/15,s on the rear(with spacers)14x6 with 225/60/14,s on front.I would check fitment on your rear with just the bare rim first to see if they hit your leafsprings first.Just my 2 cents.Hope this helps before you spend.
P.S I have a 8 3/4 s.g rearend in there now.(no spacers)
i put the wheels on without tires and they seem to have good clearance all the way around..
i went with 205/60/15 on front and 225/60/15 on rear.. will post a pic when i get them on.. hopefully they look good, and no rubbing..
yes, have u ever tried or know a tire that would work? i went with 205/60/15 gonna try them on it tommorrow
I don't think 15 x 8s on the front is a good idea. You will probably end up folding a fender when the tire hits it.
I think putting a 205 on an 8" wheel is also a bad idea.
looks like it should have plenty of clearance on the front.. what do u think the problem would be on a 205 tire/8 inch wheel
Recommended wheel width for a 205-60-15 is 5.5" - 7.5". You will be stretching the tire on a wheel it is not designed for.
Personally I would return the 8" front wheels and get 6" or maybe 7". VERY few people run an 8" wheel on the front of an a-body.
Mopar Muscle April 2010 has an article on this with a manafacturer of a product to check tire clearances.
An 8" wheel on the front will most likely rub. Remember, the car sitting statically may look ok until you test it dynamically, DRIVE IT!!! I would drop down to a 5 or 6" wheel on the front. Don't think it would look that good either, just my .02. Check out any tire manufacturer's web site and find out possible tire/wheel combos that are recommended. A 205/60 tire on an 8" wheel ain't a gonna work.
here is a pic.. just put the tires on today.. 205/60 on the front.. 225/60 on the rear.. 15x8's all the way around and doesnt even come close to rubbing!!
I still think a 205 on an 8" wheel is a bad idea. If it does rub it will be when turning and the suspension is going through its motion.
Car looks good though.
