Need some intake help
scamp72
The motor is about ready to go back in the scamp. I bought a nos kit and decided i may go woth 100 shot from time to time. I have an offy 340 intake, i read up on it. Ad says 2000 to 8000 rpm and for competition only. This is gonna be a street /strip car. Can i use this intake on the street okay? My motor is a 360 . 2.02 j heads
10 to1 forged pistons
Can i run this intake on the street?
Is it an okay intake for nos?
I read that you need a singler plane for nos? thanks guys
Yes this intake should be OK but you may loose a little bottom end because of the single plane style.
Agreed. For this intake to work well, a hi stall converter and numericaly high numbered rear ratio will help tons.
On the use of No2, a single plane works best, though a dual plane is OK. It's not a must have to run with No2.
The Offy has fuel distribution problems that can be corrected via the MoPar engines book. They tell you where to plave the fuel damns in the intake and there diamentions.
