Need some push button learnin
Discussion in 'Transmission and Drivetrain Tech' started by Blackhatguy, May 16, 2018 at 6:51 PM.
  1. Blackhatguy
    Blackhatguy Well-Known Member
    73
    18
    Dec 20, 2017
    Texas
    Local Time:
    9:03 AM
    I'm hoping a few of you guys on here are some push button transmission gurus, because I have a few questions about and upcoming build.
    I've got a long tail shaft cable shift 904 out of a 65 273 Belvedere, and a short tail shaft push button shift 904 out of a 64 Dart.
    I am planning to, assuming it's possible, take the first two gears out of the slant 6 transmission and put them into the V8 transmission. I am also planning to convert the V8 transmission to short shaft using the Slant six output shaft and tail housing. I am also wanting to keep the push button shift, do I need to use the 1964 valve body? What other problems am I missing?
    The whole point of this is because I am taking the slant 6 out and putting a V8 in.
  2. fshd4it
    fshd4it Well-Known Member
    188
    57
    Jun 9, 2016
    Winock WA
    Local Time:
    7:03 AM
    I've never heard of a long tailshaft 904. As far as I know, they're all 31" OAL. 727s, however, are 35" overall. '65 Belvedere? I'll bet you've got a 727, that's what mine came with.
    • Like Like x 1
    • Blackhatguy
      73
      18
      Dec 20, 2017
      Texas
      Local Time:
      9:03 AM
      Wow, not quite what I was expecting. I was actually hoping for a 9:04 because they draw a little less power. But at least a 727 would be a little more bulletproof right? I'll take a picture of the numbers tomorrow after work and post them up.
    • fshd4it
      188
      57
      Jun 9, 2016
      Winock WA
      Local Time:
      7:03 AM
      One easy way to tell them apart is the shape of the pans. 727s have a bump-out on th RF corner.
      • Thanks! Thanks! x 1
      • Blackhatguy
        73
        18
        Dec 20, 2017
        Texas
        Local Time:
        9:03 AM
        So I'm pretty sure just going off of the pan, that it is a 904. But it still got that crazy long tail shaft. Came back with some pics for you this time. The one sitting on the plastic is the long shaft, the clean one is the slant 6 Short shaft. Just going by the oil pan it looks like a 904...
      • fshd4it
        188
        57
        Jun 9, 2016
        Winock WA
        Local Time:
        7:03 AM
        • You're right, that's a 904. Learned something new today, thanks, wish I could do that more often. I'm not the guy to give you 904 advice (I've only rebuilt one), but I've done pretty much what you're talking about with 727s several times. The valve bodies are a little different (the '65 has room inside for one more shift of the manual valve), but I believe you can use a '65 in a pushbutton application, just not the other way around.
        • Like Like x 1
        • Blackhatguy
          73
          18
          Dec 20, 2017
          Texas
          Local Time:
          9:03 AM
          Turns out, from what I been reading, I need to transfer all the guts from the 64 slant 904 into the 65 sb 904, including the tailshaft and housing. Should be pretty straightforward..? Would be my first time inside a transmission..
        • fshd4it
          188
          57
          Jun 9, 2016
          Winock WA
          Local Time:
          7:03 AM
          There are some really good books on rebuilding torqueflites, one by Carl Munroe, one by Tom Hand, and the ATSG rebuild manual. I've got them all, they'll basically tell you everything you need to know. Other than a few special tools (which you can sometimes be creative and get by without), they're pretty straightforward and parts are readily available.
