tooslow
Every Cam manufacturer rec's buying thier springs when using thier Cam?
Can you use your existing springs if the springs are within the specs of the new Cam/ or is it just a good rule of thumb to install new springs with the new Cam?
I only use mech Flat tappet Cams because they fit my skill parameters
