need to buy Man's springs when using thier Cam
tooslow
lockport, Il
Every Cam manufacturer rec's buying thier springs when using thier Cam?
Can you use your existing springs if the springs are within the specs of the new Cam/ or is it just a good rule of thumb to install new springs with the new Cam?
I only use mech Flat tappet Cams because they fit my skill parameters
You need a spring at your installed height with the same pressures as the cam manufacturer recommends. Lift is almost irrelevant (as in seeing "my heads have .600 lift springs so I'm good..." a lot). If you have a set of springs that has been used, you should have them checked for the correct presures. Modern fast rate cams will shorten spring life, so it's always a good palce to start... Like what Artie said.
Got it--I will just go with new springs they are not to expensive.
I will add the old ones to my inventory of spare parts for another project down the road
I will invest in a valve spring gauge sounds like a good tool for down the road---Thanks
