CommieHook
Okay guys, I really need some help here. I have owned my '65 Valiant with the 170 /6 for about a year and a half. It ran fine when I bought it but I went ahead and put a new kit in the Carter BBS. Smooth running little car. Then about a month ago, it started stumbling, and it only got worse. There doesn't seem to be any rhyme or reason to when it does it. I had an old Holley 1920 that I put a kit in and then tried it. It was terrible. Couldn't tune it right, just awful. So I put the Carter back on. I have replaced the dist cap and rotor, plug wires, spark plugs, fuel filter, fuel pump, and air filter. Also adjusted the valves. One thing that makes it so frustrating is this: On a trip to pick my kids up from school, a 40 minute drive total, the first part of the trip the car might do okay, only stumbling 2 or 3 times..... then it might smooth out and be perfect....then it might stumble and backfire and just about be undriveable for a good 10 minutes, then semi-straighten up again. It doesn't seem to matter if it is under a load like pulling a hill or not. High RPMs and/or low RPMs. I just don't know what to try now.
I would love to swap another good working carb on there just to see if it is that. I have even looked at buying one on this forum. But finding a good rod-actuated Carter BBS is pretty tough...
Any ideas?
Thanks for reading.
CommieHook
Any ideas?
Thanks for reading.
CommieHook
