May 29, 2023 #1 limegreen70 Pokorny Enterprise's Joined Apr 27, 2014 Messages 2,068 Reaction score 684 Location Milton PA I am using a 727 out of a 67 plymouth. It has the single prong NSS. Can I put the later style 3 prong in it and that's it? Or.is there more that needs changed?
May 29, 2023 #2 67Dart273 FABO Gold Member FABO Gold Member Joined Oct 14, 2010 Messages 62,697 Reaction score 37,144 Location Idaho More to change, and there is some "discussion." Likely at the least you need the later "roostercomb" inside the trans
May 29, 2023 #3 Professor Fate Push the button, Max... Joined Jan 13, 2020 Messages 8,779 Reaction score 15,642 Location Wisconsin Depends what you're putting it in. You may be able to rig up a microswitch on the linkage to cover the reverse light function.
Jun 2, 2023 #4 4spdragtop Well-Known Member Joined Aug 28, 2009 Messages 44,363 Reaction score 28,986 Location Ontario Parts Unknown in our 67 the backup light switch is in shifter and NSS is 1 prong/wire. I think the 3 prong switch "includes" the reverse light circuit?
