New 470 dry sump engine
No distributor? Fancy.
I'd make everything I own a dry sump system, if I could afford it. Except the two strokes, of course.
It has a distributor but it is belt driven off the nose of the cam rather than the gear driven type that stock big blocks have. The next engine I build will not have a distributor. I'm switching over to CnP for it. (coil near plug with 8 coils)
It had 240 TrickFlows yesterday. Now it has 270 TrickFlows on it.
CnP Mucho bettero....this one will also be DBW as I'm ditching these throttle bodies.
Love the clear valve covers, that's prettt neat. I do have one question about dry sump systens though. What do they do for oil slinging if they do it at all? My old shop class instructor said that some wet sump engines use the motion of the crankshaft counterweights to pick up oil from the sump and throw it at the bottom of the piston to suck some heat out of it and keep the cylinder walls lubed. How do they accomplish this on dry sump engines? Is it even necessary?
The high power dry sump engine (NASCAR for example) use piston oilers.
Dry sump engines use the bleed oil from the rod journals to lube the cylinder walls, and there's always plenty of oil mist in a running motor.
If you look at two strokes, ALL they have is oil mist, even for the crank (some do pressure feed the crank but most don't)
The piston oilers are more about cooling than anything.
Dry sump systems usually oil better than a wet sump due to less abuse of the oil (less frictional heating and aeration)
And more power/efficiency!
It's really amazing the amount of oil that gets shook off those rockers even at that speed.....
Awesome, thanks. I figured that they did something along the lines of using a jet/nozzle.
Are you using the same intake for testing the 270?
That was the subject of some debate! The original plan was to use my Wilson M1 4500 intake with the 240 heads and then run an Indy 400-3 with the 270 heads since they are a MW port. But the Indy intake is a fairly poor design so then we got worried that the crappy intake would kill off the gains from the 270 head. No easy way around it since I don't have a ported low deck MW intake on hand. Trick Flow doesn't have a MW port size intake to go with the 270 heads so no help there and nobody else builds a low deck MW intake.
Just breaking it in on the dyno.
whats your dry sump setup like? 5 stage? 4 scavenge 1 pressure or are you using factory pump to feed the oil to the engine? did you make your owe pan? im planning to build a motor and seriously considering dry sump. thanks for any tip or direction
This is an old thread but I still have some pictures saved from that project. I used a Peterson 5 stage pump for the dry sump testing. I switched over to a Peterson belt driven pump with a wet sump later in the testing. That worked pretty well also. I still have the dry sump pan that I used during the tests if you need a pan.
