jbc426
All these numbers are off a immediately turned off engine that was driving around town for 45 mins or so
Top Rad Hose near thermostat 200
Top Rad Hose near rad inlet 180
Bottom Rad Hose 166
Water Pump inlet 155
Intake to Pump hose 199
Front side driver's head 224
Front side pass head 211 (several mins after drivers)
Pass exhaust 266
front of carb 138
Rad cap 113
Top of Plastic Rad Tank each side of Cap 186
Aluminum Intake 219
They didn't have the leakdown tester so couldn't do that.
But as I started my truck to back out of Autozone, clouds of white smoke came out like I was stoking a beehive.
And it stumbles when I first start it up. To me, that sounds like it has water in the cylinders.
I don't want it to be, but it sounds like it is.
These are normal operating temperatures. I set my twin fan thermostats using a heat gun and these are just below the temps the temps I have the second fan kick in.
You want a Leak Down tester to identify the problem. It uses your compressor to push air into the cylinder and you will hear it come out of what ever has the leak, the intake, the exhaust, the radiator will bubble etc. It will tell you what percent of the air is leaking out of a given cylinder.
Better yet, where did you say the white smoke was coming out of? It's not from the radiator overflow tube/bottle is it?
If it's near the heads/block then just pull the heads, have them magnafluxed, decked to straighten them and get a valve job done. It would be a good time to put on a new quality double roller timing chain and gears as well.
Which ever cylinder it was, it will be spotlessly clean in that one. Be sure to clean the block deck surface well and check for cracks along the surface, especially between or next to bolt holes.
Either that, or pour in a pre-mixed with water cup of aluma-seal radiator sealant. Use the powdered kind, but be sure to mix it with some water, stir it well and pour it in the radiator on a cold running engine. Don't just pour the powder into the radiator!!! Then drive for a half hour at highway and around town speeds. That may take car of the leak as well. I've seen it happen.
