nm9stheham
OK, that is all good and makes more sense. MRL is saying what I was thinking: the mechanic's info was not right. The last numbers make sense. (Being a hand's-on kinda guy, I know I would be re-checking myself! Which is what MRL is saying.... timing advance is so critical to engine operation that it HAS to be confirmed as right.)
So has this changed the engine behavior, or is it too cold to check?
And BTW, I don't throw things anymore (too expensive) but I sure do yell a lot....LOL
FWIW, on the TC and cam: The latest, higher stall TC numbers you are now getting make more sense with the cam. But I would not consider that combo to be a cruising combo..... low end RPM's are too high. If you are really going to cruise and not drag race, then I'd be thinking a cam change, not a TC change. It does not mean that you won't be happy with an engine that has a high low end operating RPM if you up the TC stall speed....I am just pointing out the application versus cam/TC choice.
Now back to your regularly scheduled program... which is fixing the stumble.
