New episode of " What's this Part"
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
Any help is appreciated. Thanks in advance !
Today I have a few more parts to ID.
#1 26" Aluminum Radiator. Only marking on it is this.
#2
Trans mount with an extra forward facing bracket.
#3
Couple engine brackets? But don't seem to fit either Small or Big Block .
&#4
Weird shaped A body kick panel.
Thanks again.
Looking for them , not finding them.
Any idea what body. Applications ?
Yup. They both appear to be driver's side A body big block mount bracket$. I BELIEVE they also fit C bodies as well, if I recall correctly.
But they don't seem to bolt to a big block. I'll check again.
The side with two bolt holes "wraps around" the front of the block and bolts to the very front of the block. The block must have the drilled and threaded bosses in front. Not all of them do. The side with one bolt hole bolts to what would be the front hole on the side of the block.
Like this:
Like this:
Do they have a right side of these ? If I try to match like your picture, the rubber mount is pointing up and out . DA.
I'm unsure if the right side is specific to the A body or not. It might work for other things.....I just don't know. But that driver's side is specific to only two applications I know of. The A body and C body.
The left kick panel likely is A-body with foot operated park brake but that would be later than 1973.
