New in Box
Max1196
Swift Current SK
Just sayin. Do you see it.
That is for a slant 6. So the guy (or robot) that machined that pin bore thought it was A OK?
Had to look it up. I don't know where anything comes from, these days.
Back in the '70's or early '80's I had a Direct Connection high compression 360 piston that I ordered through a car dealer with the pin angled even worse than that! They did replace it.
Actually I’d be pissed off the other pistons in the set were not pre-angled to compensate for the torque. That’s a speed secret I guess you are not ready for.:rofl:
I'd let them know that you're letting EVERYONE know that type of bs is inexcusable and why companies go under after screwing over customers.
I’m sure they’ll take it back and replace it. I would t bother with the threat. If they gave me ****, the threat wouldn’t be so, it would be just an incoming heads up to a future fact. I don’t see it as screwing customers, just bad work.
