new member from michigan
motorcitymagnum
metro detroit
finally signed up after years of just browsing.
I have a duster with magnum 360 and do some grudge racing for fun!
always looking for stuff to make it go faster!
thanks! motor city magnum
Welcome to FABO from the great white north!
Great lookin' car you have there!
again, thanks for the kind words fella's. weather is to be ok tomorrow, so I'm getting ready!
I think I will post combo in a few days.. motor city magnum!
since the grudge season is done for the year, here's some info for all.
by all means this isn't the fastest car, but for what's in it, I think it surprises some!!!
standard bore 360 magnum,non-stroker, edelbrock heads untouched out of the box, comp cam to my specs, 904 with stock gearing,3.55 with old mickey Thompson drag radial(255), turbo action converter(foot brake)ron francis wiring thru-out whole car,all msd,stock fuel tank with old carter mechanical fuel pump, nitrous express plate with stand alone fuel system. 750 holley with mp single plane intake(untouched)
since im going to upgrade during winter, here's how it ran last Saturday nov. 3rd
1.382 60' ft.
10.348 et 1/4 mile
126.56 mph
my goal is to go mid to low nines with magnum power before I get really serious! thanks,motorcitymagnum
1.382 60' ft.
10.348 et 1/4 mile
126.56 mph
Some impressive numbers. How much Nitrous you throwing at it?
200 shot. no nitrous jet in plate. I use n2o solenoid as jet. most nitrous company's jet on safe side, but where's the fun in that?
I will try and post some links that show good combo's for fuel/nitrous jetting. I ran almost 120lbs(12 bottles) of n2o thru season and no issues. timing/plug/fuel need to be spot on!!
just picked up another block curtesy of an a body member, dak**rt. (thanks again) work to begin as soon as shop fits me in. I will post in build section as it moves along.
happy 2019 fella's block in shop. pics to follow. doing small stuff in the meantime. out with old column and that's the last of ma'mopar wiring except headlight sockets. pics of new deal when I get it all welded up. thanks,motorcitymagnum!
update been busy with work and family and have had the duster out only 2 times this year. first time out, all garbage. took about 60lbs out of front end and just starting to get it dialed in.
2nd time out broke output shaft(snapped clean) looks like my dialing in suspension worked!!!!
was done for almost 2 months but its all back together. fingers crossed.
