autoxcuda
- Joined
- Apr 6, 2007
- Messages
- 9,523
- Reaction score
- 5,051
How's the condition of all the upper, lower and strut rod bushings?
With the car jacked up and on good jack stands, grab the tire on the edges and try to rock it side to side and up and down. Really need two people: one to rock the wheel and one to inspect each joint one by one. Need a drop light. And put your hand around each joint to feel movement (get dirty).
Repeat that by putting a second jack under the lower control arm and put some pressure on the lower control arm. Then check the upper and lower ball joints, bushings, and strut rod bushings.
If you are happy with all that, get it aligned at a good shop and have them check over the condition of the suspension too.
A master cylinder does not effect things side to side. Proportioning valve affecting is not very likely.
IIRC, some parts places are selling disc brake masters that look like drum ones with front and rear reservoirs the same size.
Rock Auto list:
And it looks like this: :banghead:
Rock Auto list:
A-1 CARDONE Part # 101326 Reman. w/ Reservoir
Front Disc brakes; Rear Drum brakes; Power brakes
