New shocks and tire fitments
Hippylong
Active Member
Fresno
Just put monroe shocks all the way around on my 1964 dart gt 4sp.
Mine were blown.
To compensate for saggy springs i put air shocks on the back at 38 lbs.
And 32022 monroe matics up front..
For like $150 total it Rides like a dream. And the stance is just what I wanted.
I have 235/60 14's all the way around.
New springs in the future!
Looking GooD !
Yep that was the same setup I had on my 64 GT and my 66 GT . I do miss my 64 .
I'm now running 15' rallies .
Did you experiment with the rear air pressure, I run mine at 12 psi. If you can have 2 seperate line to keep the car from leaning while going around corners.
I did buy the dual line kit but I didn't install it. I did not have uneven rear springs. I did a "T" between the shocks but closer to passenger side
And ran a single line in clips back.
Looks clean.
No lean..
